GRBL Settings Help
Hello Everyone,
I’m new to laser engraving, I tried to a few months back and had to put it on hold due to work. Now I’m able to focus and little more time into it. Currently, I am able to set everything up but when I click start it traces the project but the laser doesn’t fire.
I am running 1.1h and here are my current settings
Grbl 1.1h [’$’ for help]
[MSG:’$H’|’$X’ to unlock]
[MSG:Caution: Unlocked]
ok
ok
[VER:1.1h.20190825:]
[OPT:V,15,128]
Target buffer size found
ok
Homing
error:5
Homing cycle is not enabled in your Grbl settings.
$0=10 $1=255 $2=0 $3=1 $4=0 $5=1 $6=0 $10=1 $11=0.010 $12=0.002 $13=0 $20=0 $21=0 $22=0 $23=0 $24=25.000 $25=500.000 $26=250 $27=1.000 $30=1000 $31=0 $32=1 $100=100.000 $101=100.000 $102=250.000 $110=4000.000 $111=4000.000 $112=500.000 $120=500.000 $121=500.000 $122=10.000 $130=500.000 $131=400.000 $132=200.000 ok
Thanks Bo,
However, my main concern is the laser not firing. Do you see anything wrong with the settings?
Dewey
You can’t do anything when you have an error. You need to clear the error first.
