You have something else in your file, most likely off to the left of the green dot. Press Ctrl+A to select everything, then Ctrl+Shift+A to fit the selection in view. You’ll probably find there’s other stuff in your file.
mm ill share my file here if i spot it again. but ill double check.
the weard thing is i only select the circle i made. and i move it. the green dot moves in paralel even if i ungroup evrything.
il double chekc. then again the machine im using runs a older version of lightburn, ill recomand the workshop to update. heck my laptop that i use for pre loading files has a newer light burn, and i dont even own a lazer
