I have a roly lasermatic 10 watt laser where the project is on the screen and where the laser aligns to is different. I need to move project 14 mm to the left for the laser to start in the right position. the laser bed is a set position and can only move 1/16 inch max. the enclosure is solid no movement.this just started when I went back to 1.7.08 version. But I have same problem in2.0.03 version
Check Origin and Start From: settings. Also see if you have a Kerf offset in the Cuts window.
