I am running into an “issue” when using the grid array. When I use it it creates a cut path that happens twice similar to if I set it to 2 passes but I am not. It is set to 1 pass. I have attached the current file I am having issues with. This is on lighburn 1.2.04 and windows 10
Bulk-Backs.lbrn2 (23.4 KB)
It seems likely to me that the design you used as the base of the grid array likely had two sets of lines on top of one another. And that is getting duplicated across the entire array.
Start again and delete the duplicate outline prior to using the grid array.
