I’ve created a simple test pattern: two 30 cm perpendicular axes, three squares and three concentric circles of 30, 20 and 10 cm. I want to add a scale on the X and Y axes: a simple 10 mm segment replicated 15 times every 2 cm (grid array). And it’s these segments that are not burnt, even though all the objects are on the same layer with 100% power. The same phenomenon occurs with a variable text repeated to number the scale graduations (grid array with variable text/serial number) : no output (but head movements in both cases
I also used the “Bake” function: same lack of output for these repeated objects. For this engraving, instead of a laser head, I use a drawing module that supports a pen. This module is triggered when the power is set to 100%, which is the case for the entire layer. Do you have any clues?
Thank you in advance for any help.
Lightburn 1.7.06 on Linux
Laser : Tyvok Spider Laser X1 with drawing module
