Grid not fully updating when I hit update overlay
ok so long story short…
I moved my laser to re arrange my shop
using a omtech 50watt c02
I had to re aligned my mirrors, thats good now
before the move my lb camera was SPOT ON
now its at least 1/4" off and im having a really hard time getting it back to how it was
on top of that I noticed when I hit update overlay, the bottom right half of the grid stay white and won’t update but the rest of the grid is updated
When you re-run the Camera Alignment process, are you making sure to re-run the target marker engraving each time, and not to re-use a previous engraving? That’s crucial.
Here are some additional resources on the camera alignment process. Please review them to make sure you’re completing the alignment properly:
Try rerunning the alignment process, taking care to be as precise as possible when marking the targets. You can also try upscaling the size of the target engraving; increasing the distance between the targets can improve alignment.
Finally, if you are still off a bit, you can use these numbers in the Camera Control window to fine tune the placement and scale:
The ‘Shift’ values move the background image around, and the ‘Width’ & ‘Height’ values adjust the size. When you have it aligned, click ‘Save’ so the values persist.
