Grid position with longer ray 5
Hi all
Im a complete newb . I just bought a longer ray 5 10w laser and ive setup and recognized in Lightburn. When i open light but and use move everything moves correctly, when i use the laser set button on the grid in light burn it is not correct for example , i have to click the bottom left of the map to get the laser to move to actual center of the bed or if i click center on lightburn grid it moves laser to upper right out of limits causing error.
Thank for any help.
Does it have limit switches? How do you home it?
I do not have limit switches I physically move it to front left when I turn it on and set position on the laser touch screen. I ordered limit switches for it today.
You are positioning it before you turn on power right?
Yes then i turn on and hit the position marker on touch screen. Thanks
Its turned off then i position then turn on just to be clear.
I would read thru this. Especially coordinates.
Limit Switches - Diode Laser Wiki (diode-laser-wiki.com)
