Gweike Cloud 50W wont fire
Hi All,
Since I upgraded to LB 1.07.08 I am having trouble with the laser.
I am trying to cut paper, so I move the head down 16mm. When I hit start, I get the “material thickness very close to zero” warning. Then I click OK and start the job. The laser “powers up”, the button turns red and nothing happens.
I even tried moving the head only 1mm down and I get the same warning, and the same red button with no movement in the machine.
This is driving me nuts!
I would really appreciate any help.
Thanks in advance,
Don
Okay, so I got in touch with Gweike, and the tech said to check my water level in the tank.
It was about 50% of the tank.
He said to top it off and try again.
I did, and it worked perfectly, as it always did!
Something new to monitor!
I hope this helps somebody else!
