Hoping someone can help me. I am just getting started and have looked through every setting I can find in Lightburn to try to figure out why the laser is cutting everything mirrored from what is on my screen. I am using a Gweike Cloud 50wt cutter. If you happen to know any settings to get this to cutter to work in Lightburn I would be very grateful as well! None of the settings I try to get it to cut or engrave seem to work the way you would think. Please help if you can!
Check your Origin setting in Edit->Device Settings. The Origin position there should match where your laser homes, assuming it’s a Ruida controller.
