Gweike g1 lightburn/smoothieware
I posted this same thing at maker forums, and am just at the end of my rope with this…so reaching out everywhere.
I will try to explain this the best i can but i really dont speak '“tech” language, so here it goes.
bought gweike g1….bought lightburn……went through dowload and install process just as direction say. so far everything work as it should except for 1 issue.
my issue is this…..the actual machine bed is x:400 y:330 and using “MOVE’“arrows I can move laser all around bed smoothly. When I hit home the laser goes to top right corner as it should and park at actual x:0 y:0, while parked at x0y0 lightburn position says it is at x210 y220.
Now with that being said: when I use location (location button) to sent laser to or engrave in area bottom left corner lightburn sends laser to middle of laserbed but says laser is @ x400y330. now when i use move arrow buttont to move laser to bottom left corner of bed which is actually x400y330 lightbutn says it is at x650 y 510.
machine coordinates and lighburn coordinates are not lining up.
I have uninstalled and reinstalled….verified limits work…changed every setting multiple times. The laser burns fine and does nice work and all other settings and options work great i just can not get positions to match machine to program…..any ideas.
thanks
Brent L
