I do love the camera. The lens calibration wizard is “ok”, but not really working so well TBH. I have fisheye lens mode and got decent scores, but the result is still off by several mm is central area and wildly off- like 30mm- near the edge. It’s not the reproducibility of the lid position, I ran all this with the lid interlock disabled so I left it open and never touched it. And clearly not an offset prob as, even after cal, the edge of the field is bowed in by that ~30mm along the edges with uncompensated barrel distortion. Also most of the error was in left/right offset which would not be the axis with the most error if the lid were not open in the same way.
Instead of engaging LB devs to try something that might be better, it occurs to me an independent coder can do this. Like make a document with a arbitrary grid of 24 crosshairs on a black layer to burn, then take a shot with the camera, and manually create red crosshairs on the same document where the burns appear on the camera vs the black crosshairs in actual coordinates. From there, a Python script could take that .lbrn2 file of camera points, and the machine’s lbdev file, and recalculate both the lens calibration and alignment parameters and write new lens parameters back to the .lbdev file.
That would replace both the camera calibration and alignment steps, which might be able to yield better accuracy. Is that possible? Can we get a description of how the lens parameters in the XML work?
Or is the problem in barrel distortion near the edges being tens of mm off a limitation of the algorithm that tweaking the available compensation fields with better numbers wouldn’t necessarily make better?
