nanny86
(mat)
January 11, 2023, 10:59pm
1
hi all so had a new laser sainsmart 5.5w fixed focus not sure what’s happening but even 0.10% in frame is blinding were as my old laser would just shine a light that you can look at without burning retinas
also i have opened some templates i used on my old laser and its burning everything my old laser which was the same make just a variable focus its minimum power to burn was 40% but now im burning at as low as 5%
at the moment to burn simple text im having to run it at high speed to slow the burning rate down as i cant get it low enough to not burn
$0=10
$1=25
$2=0
$3=2
$4=0
$5=0
$6=0
$10=0
$11=0.010
$12=0.002
$13=0
$20=1
$21=1
$22=1
$23=3
$24=25.000
$25=500.000
$26=250
$27=1.000
$30=255
$31=0
$32=1
$100=800.000
$101=800.000
$102=800.000
$110=2000.000
$111=2000.000
$112=600.000
$120=50.000
$121=10.000
$122=10.000
$130=260.000
$131=316.000
$132=100.000
ok
s value max setting is at 255
berainlb
(PY)
January 12, 2023, 12:01am
2
Sounds like it’s configured correctly based on what you’re saying.
If the laser is modulating power at all that sounds like the wiring is correct.
Is it possible that your old module had gotten weaker and weaker over time and you hadn’t realized how much?
Try one thing, can you setup a simple job with 100% power and then save the gcode with a .txt extension and upload here? Will review to make sure the gcode looks correct for your configuration.
nanny86
(mat)
January 12, 2023, 12:20am
3
hi and thanks for the reply im not too knowledgeable with this machine is this what you wanted ?
; LightBurn 1.3.01
; GRBL device profile, current position
; Bounds: X-17.66 Y-15.46 to X17.66 Y15.46
G00 G17 G40 G21 G54
G91
M4
; Scan @ 400 mm/min, 100% power
M8
G0 X-1.31Y-15.464
; Layer C00
G1 X0.167F400S0
G1 X2.286S255
G1 X0.167S0
G1 X1.692Y0.17S0
G1 X-0.167S0
G1 X-5.67S255
G1 X-0.167S0
G1 X-0.983Y0.168S0
G1 X0.167S0
G1 X7.636S255
G1 X0.167S0
G1 X0.776Y0.17S0
G1 X-0.167S0
G1 X-9.188S255
G1 X-0.167S0
G1 X-0.662Y0.168S0
G1 X0.167S0
G1 X10.512S255
G1 X0.167S0
G1 X0.564Y0.169S0
G1 X-0.167S0
G1 X-11.64S255
G1 X-0.167S0
G1 X-0.512Y0.169S0
G1 X0.167S0
G1 X12.664S255
G1 X0.167S0
G1 X0.483Y0.168S0
G1 X-0.167S0
G1 X-13.63S255
G1 X-0.167S0
G1 X-0.422Y0.17S0
G1 X0.167S0
G1 X14.474S255
G1 X0.167S0
G1 X0.414Y0.168S0
G1 X-0.167S0
G1 X-15.302S255
G1 X-0.167S0
G1 X-0.372Y0.17S0
G1 X0.166S0
G1 X16.048S255
G1 X0.166S0
G1 X0.367Y0.169S0
G1 X-0.167S0
G1 X-16.78S255
G1 X-0.167S0
G1 X-0.332Y0.168S0
G1 X0.167S0
G1 X17.444S255
G1 X0.167S0
G1 X0.331Y0.17S0
G1 X-0.166S0
G1 X-18.108S255
G1 X-0.166S0
G1 X-0.3Y0.168S0
G1 X0.166S0
G1 X18.708S255
G1 X0.166S0
G1 X0.298Y0.17S0
G1 X-0.167S0
G1 X-19.302S255
G1 X-0.167S0
G1 X-0.281Y0.168S0
G1 X0.166S0
G1 X19.866S255
G1 X0.166S0
G1 X0.269Y0.169S0
G1 X-0.167S0
G1 X-20.402S255
G1 X-0.167S0
G1 X-0.268Y0.17S0
G1 X0.167S0
G1 X20.938S255
G1 X0.167S0
G1 X0.243Y0.168S0
G1 X-0.167S0
G1 X-21.424S255
G1 X-0.167S0
G1 X-0.243Y0.17S0
G1 X0.167S0
G1 X21.91S255
G1 X0.167S0
G1 X0.236Y0.168S0
G1 X-0.166S0
G1 X-22.384S255
G1 X-0.166S0
G1 X-0.221Y0.17S0
G1 X0.167S0
G1 X22.824S255
G1 X0.167S0
G1 X0.22Y0.168S0
G1 X-0.167S0
G1 X-23.264S255
G1 X-0.167S0
G1 X-0.212Y0.169S0
G1 X0.166S0
G1 X23.69S255
G1 X0.166S0
G1 X0.2Y0.17S0
G1 X-0.166S0
G1 X-24.09S255
G1 X-0.166S0
G1 X-0.201Y0.168S0
G1 X0.167S0
G1 X24.49S255
G1 X0.167S0
G1 X0.193Y0.17S0
G1 X-0.166S0
G1 X-24.878S255
G1 X-0.166S0
G1 X-0.182Y0.168S0
G1 X0.167S0
G1 X25.241S255
G1 X0.166S0
G1 X0.182Y0.169S0
G1 X-0.167S0
G1 X-25.604S255
G1 X-0.167S0
G1 X-0.179Y0.17S0
G1 X0.166S0
G1 X25.964S255
G1 X0.166S0
G1 X0.165Y0.168S0
G1 X-0.166S0
G1 X-26.294S255
G1 X-0.166S0
G1 X-0.166Y0.17S0
G1 X0.167S0
G1 X26.624S255
G1 X0.167S0
G1 X0.165Y0.168S0
G1 X-0.167S0
G1 X-26.954S255
G1 X-0.167S0
G1 X-0.152Y0.17S0
G1 X0.166S0
G1 X27.26S255
G1 X0.166S0
G1 X0.15Y0.169S0
G1 X-0.166S0
G1 X-27.56S255
G1 X-0.166S0
G1 X-0.15Y0.168S0
G1 X0.166S0
G1 X27.86S255
G1 X0.166S0
G1 X0.145Y0.17S0
G1 X-0.167S0
G1 X-28.148S255
G1 X-0.167S0
G1 X-0.136Y0.168S0
G1 X0.167S0
G1 X28.42S255
G1 X0.167S0
G1 X0.135Y0.17S0
G1 X-0.166S0
G1 X-28.692S255
G1 X-0.166S0
G1 X-0.136Y0.168S0
G1 X0.167S0
G1 X28.962S255
G1 X0.167S0
G1 X0.125Y0.169S0
G1 X-0.166S0
G1 X-29.214S255
G1 X-0.166S0
G1 X-0.123Y0.17S0
G1 X0.167S0
G1 X29.458S255
G1 X0.167S0
G1 X0.122Y0.168S0
G1 X-0.167S0
G1 X-29.702S255
G1 X-0.167S0
G1 X-0.122Y0.17S0
G1 X0.167S0
G1 X29.946S255
G1 X0.167S0
G1 X0.109Y0.168S0
G1 X-0.166S0
G1 X-30.166S255
G1 X-0.166S0
G1 X-0.11Y0.17S0
G1 X0.167S0
G1 X30.384S255
G1 X0.167S0
G1 X0.11Y0.168S0
G1 X-0.167S0
G1 X-30.604S255
G1 X-0.167S0
G1 X-0.107Y0.169S0
G1 X0.167S0
G1 X30.818S255
G1 X0.167S0
G1 X0.097Y0.17S0
G1 X-0.166S0
G1 X-31.014S255
G1 X-0.166S0
G1 X-0.098Y0.168S0
G1 X0.166S0
G1 X31.21S255
G1 X0.166S0
G1 X0.098Y0.17S0
G1 X-0.167S0
G1 X-31.404S255
G1 X-0.167S0
G1 X-0.095Y0.168S0
G1 X0.167S0
G1 X31.594S255
G1 X0.167S0
G1 X0.086Y0.169S0
G1 X-0.167S0
G1 X-31.766S255
G1 X-0.167S0
G1 X-0.086Y0.17S0
G1 X0.167S0
G1 X31.938S255
G1 X0.167S0
G1 X0.086Y0.168S0
G1 X-0.166S0
G1 X-32.112S255
G1 X-0.166S0
G1 X-0.084Y0.17S0
G1 X0.166S0
G1 X32.28S255
G1 X0.166S0
G1 X0.076Y0.168S0
G1 X-0.167S0
G1 X-32.43S255
G1 X-0.167S0
G1 X-0.075Y0.17S0
G1 X0.167S0
G1 X32.58S255
G1 X0.167S0
G1 X0.075Y0.169S0
G1 X-0.166S0
G1 X-32.731S255
G1 X-0.167S0
G1 X-0.075Y0.168S0
G1 X0.167S0
G1 X32.88S255
G1 X0.167S0
G1 X0.065Y0.17S0
G1 X-0.167S0
G1 X-33.01S255
G1 X-0.167S0
G1 X-0.064Y0.168S0
G1 X0.167S0
G1 X33.138S255
G1 X0.167S0
G1 X0.065Y0.17S0
G1 X-0.167S0
G1 X-33.268S255
G1 X-0.167S0
G1 X-0.064Y0.168S0
G1 X0.166S0
G1 X33.398S255
G1 X0.166S0
G1 X0.057Y0.169S0
G1 X-0.167S0
G1 X-33.51S255
G1 X-0.167S0
G1 X-0.054Y0.17S0
G1 X0.167S0
G1 X33.618S255
G1 X0.167S0
G1 X0.054Y0.168S0
G1 X-0.166S0
G1 X-33.728S255
G1 X-0.166S0
G1 X-0.054Y0.17S0
G1 X0.166S0
G1 X33.836S255
G1 X0.166S0
G1 X0.05Y0.168S0
G1 X-0.166S0
G1 X-33.936S255
G1 X-0.166S0
G1 X-0.044Y0.17S0
G1 X0.166S0
G1 X34.024S255
G1 X0.166S0
G1 X0.044Y0.168S0
G1 X-0.166S0
G1 X-34.112S255
G1 X-0.166S0
G1 X-0.044Y0.169S0
G1 X0.166S0
G1 X34.2S255
G1 X0.166S0
G1 X0.044Y0.17S0
G1 X-0.166S0
G1 X-34.288S255
G1 X-0.166S0
G1 X-0.035Y0.168S0
G1 X0.167S0
G1 X34.356S255
G1 X0.167S0
G1 X0.034Y0.17S0
G1 X-0.167S0
G1 X-34.424S255
G1 X-0.167S0
G1 X-0.034Y0.168S0
G1 X0.167S0
G1 X34.492S255
G1 X0.167S0
G1 X0.034Y0.169S0
G1 X-0.167S0
G1 X-34.56S255
G1 X-0.167S0
G1 X-0.029Y0.17S0
G1 X0.166S0
G1 X34.62S255
G1 X0.166S0
G1 X0.025Y0.168S0
G1 X-0.167S0
G1 X-34.668S255
G1 X-0.167S0
G1 X-0.024Y0.17S0
G1 X0.167S0
G1 X34.716S255
G1 X0.167S0
G1 X0.024Y0.168S0
G1 X-0.167S0
G1 X-34.764S255
G1 X-0.167S0
G1 X-0.024Y0.17S0
G1 X0.166S0
G1 X34.814S255
G1 X0.166S0
G1 X0.016Y0.169S0
G1 X-0.167S0
G1 X-34.844S255
G1 X-0.167S0
G1 X-0.015Y0.168S0
G1 X0.167S0
G1 X34.874S255
G1 X0.167S0
G1 X0.014Y0.17S0
G1 X-0.167S0
G1 X-34.902S255
G1 X-0.167S0
G1 X-0.015Y0.168S0
G1 X0.167S0
G1 X34.932S255
G1 X0.167S0
G1 X0.012Y0.17S0
G1 X-0.167S0
G1 X-34.956S255
G1 X-0.167S0
G1 Y0.168S0
G1 X0.162S0
G1 X34.966S255
G1 X0.167S0
G1 Y0.169S0
G1 X-0.162S0
G1 X-34.976S255
G1 X-0.167S0
G1 Y0.17S0
G1 X0.162S0
G1 X34.986S255
G1 X0.166S0
G1 X0.005Y0.168S0
G1 X-0.166S0
G1 X-34.996S255
G1 X-0.166S0
G1 Y0.17S0
G1 X0.166S0
G1 X34.996S255
G1 X0.166S0
G1 Y0.168S0
G1 X-0.171S0
G1 X-34.986S255
G1 X-0.166S0
G1 Y0.17S0
G1 X0.171S0
G1 X34.976S255
G1 X0.167S0
G1 X-0.005Y0.169S0
G1 X-0.167S0
G1 X-34.966S255
G1 X-0.167S0
G1 X0.005Y0.168S0
G1 X0.167S0
G1 X34.956S255
G1 X0.167S0
G1 X-0.012Y0.17S0
G1 X-0.167S0
G1 X-34.932S255
G1 X-0.167S0
G1 X0.015Y0.168S0
G1 X0.167S0
G1 X34.902S255
G1 X0.167S0
G1 X-0.014Y0.17S0
G1 X-0.167S0
G1 X-34.874S255
G1 X-0.167S0
G1 X0.015Y0.168S0
G1 X0.167S0
G1 X34.844S255
G1 X0.167S0
G1 X-0.016Y0.169S0
G1 X-0.166S0
G1 X-34.814S255
G1 X-0.166S0
G1 X0.024Y0.17S0
G1 X0.167S0
G1 X34.764S255
G1 X0.167S0
G1 X-0.024Y0.168S0
G1 X-0.167S0
G1 X-34.716S255
G1 X-0.167S0
G1 X0.024Y0.17S0
G1 X0.167S0
G1 X34.668S255
G1 X0.167S0
G1 X-0.025Y0.168S0
G1 X-0.166S0
G1 X-34.62S255
G1 X-0.166S0
G1 X0.029Y0.17S0
G1 X0.167S0
G1 X34.56S255
G1 X0.167S0
G1 X-0.034Y0.169S0
G1 X-0.167S0
G1 X-34.492S255
G1 X-0.167S0
G1 X0.034Y0.168S0
G1 X0.167S0
G1 X34.424S255
G1 X0.167S0
G1 X-0.034Y0.17S0
G1 X-0.167S0
G1 X-34.356S255
G1 X-0.167S0
G1 X0.035Y0.168S0
G1 X0.166S0
G1 X34.288S255
G1 X0.166S0
G1 X-0.044Y0.17S0
G1 X-0.166S0
G1 X-34.2S255
G1 X-0.166S0
G1 X0.044Y0.168S0
G1 X0.166S0
G1 X34.112S255
G1 X0.166S0
G1 X-0.044Y0.169S0
G1 X-0.166S0
G1 X-34.024S255
G1 X-0.166S0
G1 X0.044Y0.17S0
G1 X0.166S0
G1 X33.936S255
G1 X0.166S0
G1 X-0.05Y0.168S0
G1 X-0.166S0
G1 X-33.836S255
G1 X-0.166S0
G1 X0.054Y0.17S0
G1 X0.166S0
G1 X33.728S255
G1 X0.166S0
G1 X-0.054Y0.168S0
G1 X-0.167S0
G1 X-33.618S255
G1 X-0.167S0
G1 X0.054Y0.17S0
G1 X0.167S0
G1 X33.51S255
G1 X0.167S0
G1 X-0.057Y0.169S0
G1 X-0.166S0
G1 X-33.398S255
G1 X-0.166S0
G1 X0.064Y0.168S0
G1 X0.167S0
G1 X33.268S255
G1 X0.167S0
G1 X-0.065Y0.17S0
G1 X-0.167S0
G1 X-33.138S255
G1 X-0.167S0
G1 X0.064Y0.168S0
G1 X0.167S0
G1 X33.01S255
G1 X0.167S0
G1 X-0.065Y0.17S0
G1 X-0.167S0
G1 X-32.88S255
G1 X-0.167S0
G1 X0.075Y0.168S0
G1 X0.167S0
G1 X32.731S255
G1 X0.166S0
G1 X-0.075Y0.169S0
G1 X-0.167S0
G1 X-32.58S255
G1 X-0.167S0
G1 X0.075Y0.17S0
G1 X0.167S0
G1 X32.43S255
G1 X0.167S0
G1 X-0.076Y0.168S0
G1 X-0.166S0
G1 X-32.28S255
G1 X-0.166S0
G1 X0.084Y0.17S0
G1 X0.166S0
G1 X32.112S255
G1 X0.166S0
G1 X-0.086Y0.168S0
G1 X-0.167S0
G1 X-31.938S255
G1 X-0.167S0
G1 X0.086Y0.17S0
G1 X0.167S0
G1 X31.766S255
G1 X0.167S0
G1 X-0.086Y0.169S0
G1 X-0.167S0
G1 X-31.594S255
G1 X-0.167S0
G1 X0.095Y0.168S0
G1 X0.167S0
G1 X31.404S255
G1 X0.167S0
G1 X-0.098Y0.17S0
G1 X-0.166S0
G1 X-31.21S255
G1 X-0.166S0
G1 X0.098Y0.168S0
G1 X0.166S0
G1 X31.014S255
G1 X0.166S0
G1 X-0.097Y0.17S0
G1 X-0.167S0
G1 X-30.818S255
G1 X-0.167S0
G1 X0.107Y0.168S0
G1 X0.167S0
G1 X30.604S255
G1 X0.167S0
G1 X-0.11Y0.169S0
G1 X-0.167S0
G1 X-30.384S255
G1 X-0.167S0
G1 X0.11Y0.17S0
G1 X0.166S0
G1 X30.166S255
G1 X0.166S0
G1 X-0.109Y0.168S0
G1 X-0.167S0
G1 X-29.946S255
G1 X-0.167S0
G1 X0.122Y0.17S0
G1 X0.167S0
G1 X29.702S255
G1 X0.167S0
G1 X-0.122Y0.168S0
G1 X-0.167S0
G1 X-29.458S255
G1 X-0.167S0
G1 X0.123Y0.169S0
G1 X0.166S0
G1 X29.214S255
G1 X0.166S0
G1 X-0.125Y0.17S0
G1 X-0.167S0
G1 X-28.962S255
G1 X-0.167S0
G1 X0.136Y0.168S0
G1 X0.166S0
G1 X28.692S255
G1 X0.166S0
G1 X-0.135Y0.17S0
G1 X-0.167S0
G1 X-28.42S255
G1 X-0.167S0
G1 X0.136Y0.168S0
G1 X0.167S0
G1 X28.148S255
G1 X0.167S0
G1 X-0.145Y0.17S0
G1 X-0.166S0
G1 X-27.86S255
G1 X-0.166S0
G1 X0.15Y0.168S0
G1 X0.166S0
G1 X27.56S255
G1 X0.166S0
G1 X-0.15Y0.169S0
G1 X-0.166S0
G1 X-27.26S255
G1 X-0.166S0
G1 X0.152Y0.17S0
G1 X0.167S0
G1 X26.954S255
G1 X0.167S0
G1 X-0.165Y0.168S0
G1 X-0.167S0
G1 X-26.624S255
G1 X-0.167S0
G1 X0.166Y0.17S0
G1 X0.166S0
G1 X26.294S255
G1 X0.167S0
G1 X-0.166Y0.168S0
G1 X-0.166S0
G1 X-25.964S255
G1 X-0.166S0
G1 X0.179Y0.169S0
G1 X0.167S0
G1 X25.604S255
G1 X0.167S0
G1 X-0.182Y0.17S0
G1 X-0.166S0
G1 X-25.242S255
G1 X-0.166S0
G1 X0.182Y0.168S0
G1 X0.166S0
G1 X24.878S255
G1 X0.166S0
G1 X-0.193Y0.17S0
G1 X-0.167S0
G1 X-24.49S255
G1 X-0.167S0
G1 X0.201Y0.168S0
G1 X0.166S0
G1 X24.09S255
G1 X0.166S0
G1 X-0.2Y0.17S0
G1 X-0.166S0
G1 X-23.69S255
G1 X-0.166S0
G1 X0.212Y0.169S0
G1 X0.167S0
G1 X23.264S255
G1 X0.167S0
G1 X-0.22Y0.168S0
G1 X-0.167S0
G1 X-22.824S255
G1 X-0.167S0
G1 X0.221Y0.17S0
G1 X0.166S0
G1 X22.384S255
G1 X0.166S0
G1 X-0.236Y0.168S0
G1 X-0.167S0
G1 X-21.91S255
G1 X-0.167S0
G1 X0.243Y0.17S0
G1 X0.167S0
G1 X21.424S255
G1 X0.167S0
G1 X-0.243Y0.168S0
G1 X-0.167S0
G1 X-20.938S255
G1 X-0.167S0
G1 X0.268Y0.169S0
G1 X0.167S0
G1 X20.402S255
G1 X0.167S0
G1 X-0.269Y0.17S0
G1 X-0.166S0
G1 X-19.866S255
G1 X-0.166S0
G1 X0.281Y0.168S0
G1 X0.167S0
G1 X19.302S255
G1 X0.167S0
G1 X-0.298Y0.17S0
G1 X-0.166S0
G1 X-18.708S255
G1 X-0.166S0
G1 X0.3Y0.168S0
G1 X0.166S0
G1 X18.108S255
G1 X0.166S0
G1 X-0.331Y0.17S0
G1 X-0.167S0
G1 X-17.444S255
G1 X-0.167S0
G1 X0.332Y0.169S0
G1 X0.167S0
G1 X16.78S255
G1 X0.167S0
G1 X-0.367Y0.168S0
G1 X-0.166S0
G1 X-16.048S255
G1 X-0.166S0
G1 X0.372Y0.17S0
G1 X0.167S0
G1 X15.302S255
G1 X0.167S0
G1 X-0.414Y0.168S0
G1 X-0.167S0
G1 X-14.474S255
G1 X-0.167S0
G1 X0.422Y0.17S0
G1 X0.167S0
G1 X13.63S255
G1 X0.167S0
G1 X-0.483Y0.168S0
G1 X-0.167S0
G1 X-12.664S255
G1 X-0.167S0
G1 X0.512Y0.169S0
G1 X0.167S0
G1 X11.64S255
G1 X0.167S0
G1 X-0.564Y0.17S0
G1 X-0.167S0
G1 X-10.512S255
G1 X-0.167S0
G1 X0.662Y0.168S0
G1 X0.167S0
G1 X9.188S255
G1 X0.167S0
G1 X-0.776Y0.17S0
G1 X-0.167S0
G1 X-7.636S255
G1 X-0.167S0
G1 X0.983Y0.168S0
G1 X0.167S0
G1 X5.67S255
G1 X0.167S0
G1 X-1.692Y0.17S0
G1 X-0.167S0
G1 X-2.286S255
G1 X-0.167S0
M9
G1 S0
M5
; return to starting pos
G0 X1.31Y-15.464
M2
berainlb
(PY)
January 12, 2023, 1:11am
4
nanny86:
S255
Looks like power levels are fine. So short of your controller malfunctioning it seems like it’s working as it should.
You may want to ask Sainsmart to confirm what you’re seeing is to be expected.
system
(system)
Closed
February 11, 2023, 1:11am
5
