Halftone in lightburn
What is the best setting for halftone on Lightburn so don’t get moray
Make sure your DPI setting is enough larger than the cells per inch setting that the halftone dots are 5 to 6 pixels wide. So, if you are using 254 DPI, the biggest I’d recommend is 50 cells. If your DPI is 500, then you could go to 100 cells. If you want to preview it, there’s an option to save a processed bitmap that you can view as an image under Tools > Save Processed Bitmap. That will give you the best indication of whether the image is going to have visible moire effects.
