That’s good. It’s likely in the previous tests that one of these conditions were present:
the laser head was moved by hand after homing. If you do this, the controller cannot account for the movement and will no longer have tracking of position
the location of the head was in a position that it could not reach when having to accommodate the -16 mm offset
You should be able to sort out which is the case here and avoid that going forward.
Then possibly the other scenario. I’d encourage you to experiment with placement along the left edge of the workspace where you may be more liable to have this issue.
In any case, it sounds like you’re now in working order. Go have some fun.
does the same thing on the right hand side. if i try to run anything using absolute coordinates. i believe the problem is the settings for the space for the Xtool D1 Pro 20W is not set correctly but cant find anyone who can tell me what the correct space is. The 20W laser is bigger the the 5W or 10W and can not travel as far along the X and Y axis. i dont think the X 430mm and Y 400mm are correct for the 20W. I would like to see what those settings are from someone using the D1 Pro 20W
Have you checked in XCS? It’s possible that you need to make a change there to indicate the different laser module. That may make adjustment to these settings. I recall that’s necessary for the use of the extension but I’m not certain about laser modules.
Unfortunately xTool prevent you from making configuration changes directly so won’t be able to change that directly from LightBurn although you could potentially just work around it.
Make sure that you change this in Edit->Device Settings.
again, my frustration. Lightburn relies on the config file from XCS. I have imported the correct config file from XCS into Lightburn and it does not control the 20W laser correctly. Like i said before, Lightburn does not offer 100% support for the Xtool D1 PRO 20W laser machine.
LightBurn does not use a config file from XCS. XCS itself has to configure something that xTool does not allow other programs to change.
This is an xTool created .lbdev file that they make available to ease LightBurn configuration. This is done instead of manually creating this which makes sense for xTool because they require quite a few uncommon configurations.
I guess this is a matter of perspective then. If by 100% you mean that LightBurn can manage all aspects of the machine then no. It can’t exactly do this for any machine from that perspective. If there’s a lower standard of being able to operate a properly configured machine to very high standards then yes, it is supported. However, it can’t make changes to a controller where this is disabled.
If that’s a priority for you then I’d suggest a more open machine that does allow this. Pretty much all other companies running GRBL based boards have now moved to allowing GRBL configuration changes. Even a year ago this wasn’t true.
Did you confirm that the file extension is indeed .clb? It’s likely that it wasn’t renamed correctly. Do you possibly have file extensions hidden in Windows?
In parentheses because I haven’t changed them, but have been generated by either firmware or the .lbdev file that XTool provides.
As for the topic of Lightburn not supporting XTool 100%, while that is true (with every third party software), it is also perfectly understandable.
I’d take 80%, heck, probably even 60%.
As a BEng mech. I was sold to XTool (20W + 2W + RA2 Pro + Extension) by the astonishing (in reviews also) craftmanship and quality of the mechanical construction and -features, but had I taken a closer look at the controller/firmware and especially the utter POS XCS, I might have very well chosen differently.
Or at least explored the possibilities of swapping the controller for something more “open”.
I still may ;).
Without Lightburn, my recently purchased D1 Pro 20W would probably be sitting idle, at least until I’d find some (other than XCS) reason to buy a heftier laptop.
The computer requirements to run XCS are IMHO insane, especially for those of us who insist on using laptops.
And those requirements are for a software that looks suspiciously similar to Win Paint(brush?),
while Lightburn probably (I haven’t tested…yet ;)) on most of the laptops and desktops that have been available for the last decade or so and can be had for free, or for afew tenners because modern games won’t run on those.
Hate to tag onto an old thread but I’m new to the xtool D1 pro and I am running into similar issues with LB. I attached what is happening. I just replaced the motherboard ( 1 month after getting the xtool ) per the company because they couldn’t help.
Seems like XCS works, it’s just LB. Any help or suggestions? When I try to frame or run keeps saying upper limit other limit triggered
