hi there. Can someone help me know how to import a svg or pdf from a paper print so that the cutter does not have to be adjusted too much to cut the size of some labels correctly? My cutter is Laser Master 2pro s2
I would suggest you review Print and Cut functionality which is the most generalized way of handling what you’re describing if I’m understanding you correctly.
Can you upload your SVG or PDF file?
