Having an issue w/ Lightburn to Snapmaker 2 350 getting use of full bed
I have a file that is a 11.5 inch circle. I have utilized start from current position. The laser frames to the left about 25mm further than the project should be. The print is about the same 25mm to the left off center. I am not able to get the full 11.5 inches to print on the board. I have tried the following:
  1. made sure machine settings are 320mm 360 mm bed.
  2. set start origin at left bottom.
  3. can use smaller boards and use all of them.
    I’m just new to Lightburn. In Luben I have no issues centering work and utilizing entire 320mm .
Figured it out, Had a rogue line that I could not see on the page. Got rid of Dubbles and it was gone.
