Having trouble getting a fill on this file
I have been trying to troubleshoot this for a few hours, and have to give up. I designed it on LB (latest version) Mac OS. I took it to a win 10 computer hooked to a Thunder 100w. I am trying to fill or engrave this. For some reason when I select fill on the cuts/layers window, I can’t see the fill on Mac OS. When I am on the windows computer, the fill shows up, but it is in the enclosed triangle or the “A” looking part at about 3.1 x 2.4 inches on the grid.
I am not sure if I am doing anything wrong or the software doesn’t know what I want here. It seems to want to fill the triangle inside the “A”. I didn’t go through with my cut. I need everything filled except the inside of the “A” if that makes sense.
I finally needed to reach out to you guys. I checked bezier points and have everything grouped.
Thanks.
can’t fill file.lbrn2 (24.4 KB)
  1. Use Close With Tolerance, and check Join With Line. I move the slider until it fills. In the original, it would close to a point, which I knew was wrong, so Move Ends Together was not it.
  2. At the upper right, there was a second line on top of the end part. I moved it put so you could see it.
This help?
can’t fill file-FIX.lbrn2 (24.8 KB)
Yes. Thanks.
Appreciate it.
