Having trouble with opening or importing files
We are experiencing a problem with opening or importing files. Most of the files are not Lightburn files. So when we try to use a file, we switch the file type from a Lightburn file to a different format using the file type selection? Some will open, most just show a blank box.
Normally you’d open native LightBurn files such as .lbrn and .lbrn2 and import foreign files like SVG, PDF, JPG, PNG.
Do you have examples of files that are not working as you’d expect?
I realised that dxf files needed to be 2018 and the autocad file had to be just the workspace and no other layouts to import properly at the correct size. It looked black but the content was tiny and way way from centre, so appearing to be blank
