Hi, can you advise me? Does not work my home and the laser goes mirrored on the contrary. He writes an error 5. I have windows 10, lightburn 0.9.10 and eleksmaker A3 pro with Eleksman SE.
Are you too lazy to use Google?
Here you can find all about Grbl.
Error:5 is “homing not enabled”. You cannot home a laser if it does not have homing switches installed and the homing settings configured. You also need to put your origin in the front left, not rear right, for Grbl, which is why your output is mirrored.
