HEBREW and right to left support
Hi, I’m trying to use Hebrew language with LightBurn.
I would like to engrave something not as a shape or path, but to have it engrave as an arc.
After writing some words in Hebrew fonts, I’m clicking the BLUE point and the whole sentence turn backward from left to right.
Can someone help? Its urgent.
Thanks.
I’m seeing the same thing. I suspect this is a bug in right-to-left text support with that particular feature.
It seems this issue also affects “Apply path to text”
@LightBurn may be able to confirm.
As a workaround, you should be able to write the letters backwards. With reverse ordering when bent it should look “correct”.
