i have a problem with my laser i put a model to cut which have 120mm height and my laser cut a 152mm but width cuted same as a design can someone help me with that please?
Most likely, the rotary is enabled:
It’s all too easy to hit that switch by accident!
If you don’t have a rotary, you can remove that switch:
no its not enabled bu the problem is here anyways
Have you calibrated the X and Y axis motion?
The doc explains how to do this:
yeah the calibration is problem thanks for help now i understand calibration!
