Hello group, how do I get that separated look of the blue L to look like the other L in the engraved image. Any help will be appreciated
LA2
rams
Shift click on the blue layer in your LAYERS/CUTS window to select the blue color object
CTRL+D to duplicate, then set aside the extra blue L
ALT+O or Click on OFFSET SHAPE image
Then select all the L shape inside the A - click on GROUP objects
While blue L is selected, hold CTRL and click on Red A to select both. Press CTRL+B to open Boolean shapes. Choose the option that cuts the L from the A
Go back to the duplicate copy of the L from step 2 - move it to the place desired.
Thanks Jim. Worked out great.
