So I’m cutting chipboard and have a fixed point laser that when some pieces are cut they fall and sometimes raise up so that the laser body hits this piece and moves the base.
So is there a way to cut the shape but leave it attached at a few points. I have messed with perforation mode but since each shape is a different size I can’t figure out the spacing. Is there some other setting for this? Thanks in advance
Tabs / bridges are your friend! Select the layer on which you wish to build your bridges/tabs and just about mid-point you’ll see the dialog box. If you enable it in manual mode, the icon on the left is a square with a few missing segments, which allows you to place as desired. The TechAngel link probably covers that.
