Hi All,
I am about at my wits end trying to learn how to engrave wood through a mask/transfer tape. I am using the Elegoo Phecda 20 watt. The mask I bought is the tapeman 12" roll I have seen in so many youtube videos on this subject. I have run numerous materials tests, tweaked air flow from off, to barely a stream to full blow. Small script like text does not even burn the tape away. Larger bolds and block fonts will burn the tape away. However, both leave scorch residue under the tape. I even decided to go buy a couple rolls of different brands of normal masking tape with the same results. Speeds have been from 5000 mm/m up to just shy of 10k mm/m. Power settings ranging from 50 to 100. I even played around with constant power on and off. All tests were done at 1 pass. Oh, line interval was always at 0.1000 mm. Can anyone give me some direction on what I am missing here. Please!
Thanks!
Travis
