I’m trying to edit this so that the only parts remaining are where the two circles and the rectangle intersect. Can this be done in Lightburn?
Hi,
I’m not a pro in Lightburn but I think the designing options are pretty basic here. I would recommend using Gimp or Illustrator/Photoshop for these kind of tasks and then import them into lightburn.
- Select both circles, then group them.
- Select grouped circles and rectangle
- Tools->Boolean Intersection
LightBurn provides ‘Boolean Tools’ that will produce what you are after. Here I show in wireframe and have the circles grouped and then select all, then select ‘Tools’→’Boolean Assistant’ to visually ‘see’ the different options live, as you check the buttons available. ![]()
+1 to Rick and… FWIW, Boolean works on only two group/shapes at a time. If you are having trouble with the Boolean tools, make sure you are only grabbing two things. The Booleans are among my favorite tools to use.
