So this just started happening on Friday, but engraves are now shifting over to the left or right during an engrave. I’ve tried multiple different places on the machine, had other another user test my file, and even replicated the issue with a different engrave, and even rotated the file 90* and the error still happens at the same X position, it did not rotate with the file.
I can’t seem to determine what is happening and need help!
You can even see in the images attached that after it shifts, the laser now seems to relocated it’s “absolute coordinate” to that position as the cut is then off-center as well.
Any ideas?
