For a galvo, use the materials test, the interval can be varied just like the other variables…
This is a dog tag off my fiber… I’m varying the interval …
Galvos are fast, however, you are still dealing with mass and velocity and they are usually set to a conservative value - meaning it’s unlikely that most people will change these.
I changed mine because the data sheet, what little bit there was, indicated my values to be too high. It did effect job time… it was closer to the estimated value by Lightburn.
There is timing between the axes that may need adjusting. If you’re interested, check out this video for a better explanation.
