I have searched around the forum and done a good search, I see people have an issue here or there about doing a material test on rotary, but not how they got the test on the rotary. I would like to use my rotary tool and make a test card on a tumbler, but don’t see any settings for the rotary.
Hello, Christopher
I have a project on the table right now but in the morning I was going to put the rotary back on it, I’ll check it out. Never tried that before. You tried to enable rotary and then just go to material test?
If someone more knowledgeable doesn’t come along in the meantime I’ll let you know what I come up with.
I never saw anything about rotary in the dialog box, so I was scared to move forward, but yes, if you enable the rotary before you go into the Material Test dialog box, when you Start it, it will bring up your Rotary dialog box. Working perfect now. Thanks for the help.
