Hello, I wanted to by a laser module with a higher capacity for my machine and wanted to know if buying the LT-4LDS-V2 with an air assit is better than only buying the K30?
My main goal is to cut through 9mm MDF without burning it and I don’t mind the speed if it can be done with multiple passes.
I also want to understand the importance of using an air assit and whether it is absolutely necessary to decide between the two cost wise because I can only afford the V2 with an air assist.
