Couple of days ago i successfully aligned the mirrors from scratch, or so i thought. Russ’s methods were used.
Went to cut something big today (900x600 bed) and noticed bad cuts in one corner.
Recheck:
Mirror 1 to 2 beam is dead center and parallel with Y motion.
Mirror 2 to 3 beam is also dead center and parallel to X motion on far end.
However, if i move Y all the way back my beam is HIGH ? How ?
If i turn mirror down where its high, its going to be low on near end.
Doing my head in.
Y rails not parallel to each other ? Spot on on near end, low on far end ?
Have you measured the height from bed to laser head and/or focus lens at all 4 corners? it seem your laser bed plane is not parallel to gantry x/y plane.
Now that the rails are level with each other you should check the distance from the nozzle to the bed in all 4 corners and center to make sure your focus distance doesn’t vary across the table.
Thats the idea. However i’m in a process of ordering flat steel table cut as i cannot trust honeycomb with this one bit. I always had trouble with focusing properly throughout the size of my HC.
Nozzle to table subframe seems to be ok, but honeycomb over it - focus is all over the place. Not sure how to “level” honeycomb for it to be consistent at all places. Ideas ?
Immediate use now is PETG cutting. Its thin, its floppy - honeycomb is a must.
In near future i expect to cut leather, which is also asking for honeycomb use.
Just trying to figure out how to flatten it properly.
But yeah, i see how people dont like honeycomb. Havent got enough experience lasering to rant on about that yet. Just trying to make damn thing flat.
Well if you find a good technique for flattening the thing let me know.
About the only thing I use it for now is the occasional rubber stamp. The stamps usually only cover a few square inches so “flat” doesn’t matter much.
Curious about your shimming method. I have the same problem with drifting spot and I’m sure I need to raise my right rail to create a plane. What material/ technique did you use to get it right at every single screw hole along the rail?
