My coordinates are -622.50,622.50 I get an alarm 9 when I home, and my y axis doesn’t always move. I have no idea how to make any of this work and I am ready to give up!! Please help me!!
Type the following in Lightburn console and copy past here all the output:
- 1, $I
$I
ok
[G54:0.000,0.000,0.000]
[G55:0.000,0.000,0.000]
[G56:0.000,0.000,0.000]
[G57:0.000,0.000,0.000]
[G58:0.000,0.000,0.000]
[G59:0.000,0.000,0.000]
[G28:0.000,0.000,0.000]
[G30:0.000,0.000,0.000]
[G92:0.000,0.000,0.000]
[TLO:0.000]
[PRB:0.000,0.000,0.000:0]
ok
<Idle|WPos:-622.500,622.500,0.000|FS:0,0|Ov:100,100,100|A:S>
ok
$0=10
$1=250
$2=0
$3=0
$4=0
$5=0
$6=0
$10=0
$11=0.010
$12=0.002
$13=0
$20=0
$21=0
$22=1
$23=1
$24=1500.000
$25=4500.000
$26=20
$27=3.000
$30=1000.000
$31=0.000
$32=1
$100=80.000
$101=80.000
$110=10000.000
$111=10000.000
$120=500.000
$121=500.000
$130=400.000
$131=415.000
ok
Sorry I had to leave in a hurry.
In Lightburn console type G10 L2 P1 X0 Y-415.
e[0;31mE (25766870) gpio: gpio_isr_handler_remove(480): GPIO isr service is not installed, call gpio_install_isr_service() firste[0m
e[0;31mE (25766871) gpio: gpio_isr_handler_remove(480): GPIO isr service is not installed, call gpio_install_isr_service() firste[0m
ALARM:9
Homing fail. Could not find limit switch within search distance. Defined as 1.5 * max_travel on search and 5 * pulloff on locate phases.
ALARM:3
Reset while in motion. Grbl cannot guarantee position. Lost steps are likely. Re-homing is highly recommended.
ok
e[0;31mE (25776321) gpio: gpio_isr_handler_remove(480): GPIO isr service is not installed, call gpio_install_isr_service() firste[0m
e[0;31mE (25776323) gpio: gpio_isr_handler_remove(480): GPIO isr service is not installed, call gpio_install_isr_service() firste[0m
e[0;31mE (25776324) gpio: gpio_isr_handler_remove(480): GPIO isr service is not installed, call gpio_install_isr_service() firste[0m
e[0;31mE (25776325) gpio: gpio_isr_handler_remove(480): GPIO isr service is not installed, call gpio_install_isr_service() firste[0m
spindle_pwm_off_value:0.000000 spindle_pwm_min_value:0.000000 spindle_pwm_max_value:1023.000000
Grbl 1.3a [‘$’ for help]
[MSG:‘$H’|‘$X’ to unlock]
[MSG:Caution: Unlocked]
ok
This is what happened when I entered that and tried to home it.
Just checked a video of a Creality falcon 2 homing front left.
Did you changed anything as per $ settings?
Does your laser originaly homes front left?
Type $RST=*
Type $$ and post output here please
When I had my rotary attachment on I had to change the $101 but I switched it back to 80 when I took the rotary attachment off. The software that it came with to install into lightburn it automatically was set to home to the front left.
Type first $RST=*
Type $$ and post output here.
[MSG:Restoring defaults]
ok
e[0;31mE (705002) gpio: gpio_isr_handler_remove(480): GPIO isr service is not installed, call gpio_install_isr_service() firste[0m
e[0;31mE (705003) gpio: gpio_isr_handler_remove(480): GPIO isr service is not installed, call gpio_install_isr_service() firste[0m
e[0;31mE (705005) gpio: gpio_isr_handler_remove(480): GPIO isr service is not installed, call gpio_install_isr_service() firste[0m
e[0;31mE (705006) gpio: gpio_isr_handler_remove(480): GPIO isr service is not installed, call gpio_install_isr_service() firste[0m
And the $$ output?
$0=10
$1=250
$2=0
$3=4
$4=0
$5=0
$6=0
$10=1
$11=0.010
$12=0.002
$13=0
$20=0
$21=0
$22=1
$23=3
$24=1500.000
$25=4500.000
$26=20
$27=3.000
$30=1000.000
$31=0.000
$32=1
$100=80.000
$101=80.000
$110=10000.000
$111=10000.000
$120=500.000
$121=500.000
$130=400.000
$131=415.000
ok
Type G10 L2 P1 X0 Y0.
And power cycle the laser also unplug the USB cable.
ok
G10L2P1X0Y0
ok
Port failed to open - already in use?
e[0;32mI (13820) serial: Line state changed! dtr:0, rst:0e[0m
e[0;32mI (14016) serial: Line state changed! dtr:0, rst:0e[0m
e[0;32mI (15276) serial: Line state changed! dtr:0, rst:1e[0m
ok
ok
Homing
e[0;31mE (15745) gpio: gpio_isr_handler_remove(480): GPIO isr service is not installed, call gpio_install_isr_service() firste[0m
e[0;31mE (15747) gpio: gpio_isr_handler_remove(480): GPIO isr service is not installed, call gpio_install_isr_service() firste[0m
ALARM:9
ALARM:3
ok
e[0;31mE (23878) gpio: gpio_isr_handler_remove(480): GPIO isr service is not installed, call gpio_install_isr_service() firste[0m
e[0;31mE (23880) gpio: gpio_isr_handler_remove(480): GPIO isr service is not installed, call gpio_install_isr_service() firste[0m
e[0;31mE (23882) gpio: gpio_isr_handler_remove(480): GPIO isr service is not installed, call gpio_install_isr_service() firste[0m
e[0;31mE (23883) gpio: gpio_isr_handler_remove(480): GPIO isr service is not installed, call gpio_install_isr_service() firste[0m
ok
This is what I got when I powered everything back on and plugged the usb back in
<Idle|MPos:-30.000,-30.000,0.000|FS:0,0|WCO:0.000,0.000,0.000>
But the position is now -30 instead of -622.5
Should be 0,0
I tried it again and still -30
When you power cycle did you wait at least 15s?
Yes. I waited 30 seconds
Sorry -30,-30 is Mpos.
Move your laser head to the center of the bed.
And run a home cycle.
I´m not thinking very right today it has been a hell of a weekend.
When I ran it from the center it is now 3,3
