Introduction
I recently acquired a second-hand CO2 laser machine of Chinese manufacture. This machine is equipped with an 80-watt laser tube and has a cutting area of 70x50 cm. It comes with an RDC6442S-B(EC) controller and also features a motorized leveling system, though the motors are not stepper motors.
https://www.usinages.com/attachments/1-6-jpg.847732/
https://www.usinages.com/attachments/1-1-jpg.847737/
Encountered Problem
I am contacting you today because I am encountering a problem with my laser machine. While attempting to initiate a cut via LightBurn, an error message appeared on the machine’s control screen indicating there was insufficient space on the cutting bed.
This is not the first time I have faced this issue. Usually, when this error appears, I restart the machine. However, after attempting this solution, the machine starts behaving strangely: it no longer performs its homing process, the axes jerk, and it makes a loud noise, as if the machine is straining during movements, with a distinctly loud sound. This issue consistently occurs after the error message is displayed, but otherwise, the machine works well.
Attempted Solutions
In the past, restarting the machine by unplugging its power supply solved the problem, and I was able to reuse the laser machine without any trouble. Unfortunately, even after several days and attempts, this no longer changes anything: it refuses to perform the homing process.
I would be very grateful for any assistance you could provide to resolve this issue.
Thank you in advance for your support.
Best regards,
