Help needed with calibration type cut using auto movement of bed ( Z ) and head ( X )?
Hi all, I am trying to do a mode burn using acrylic which basically sends a pulse to the head every 10mm of movement on the X Axis. After each movement I would like the bed to move down 1mm or 2mm before the next pulse but I have not got a clue how to do this. Can anyone help please ?
I have a 600mm x 500mm bed with stepper motors on the X Y and Z Axis and a RUIDA 6442 controller.
Any help appreciated :+1:
I don’t have a Z stepper on mine, but it seems to me there is no control over Z once the layer is executing.
Hang around and see if someone else know different.
Thanks Jack, but I must say I have seen Russ doing exactly this in one of his videos but could not see how he did it!!!
I’m sure someone must know!!!
Rgds
Kev
He does not use Lightburn.
Hi Jack
That may be the situation as he uses RDWorks but I thought Lightburn was supposed to be a step ahead of that software!! I will try and ask the same question on the RDWorks forums.
Cheers
Kev
There are a few things you can do with RDWorks, that don’t seem to have a counterpart in Lightburn, such as the Blow option to control how wind is handled.
If you get a controller that has this set to when the laser is enabled, it will turn you air assist on/off along with the L-On operation.
As far as I know the only way to change this is to run the right version of RDWorks and change it… There’s no way I know of to change this from within Lightburn.
Doesn’t make the software worse. There’s likely lots of things about a Ruida that are unknown.
Are you looking at some kind of focal point test?
Yes Jack, I have posted on RDWorks Facebook page to see if anything pops up there. I have tried other methods but the dot method on acrylic is what I am really after.
Thanks
I get it, hang around, there are others. Sometimes this work on one model, but not another, so I’m interested.
I have the stuff to put a stepped Z together, but when I really looked at it with more detail, my OMTech does not have straight screws for each of the 4 corners, so moving Z would be more of a nightmare than a benefit, in my case.
