I have a problem that the burn is noch accurate some lines move in y direction.
as you can see in the picture. (for example the 4 is too low or the boxes are not aligned)Material didn’t move, I checked it.
And the model looks okay in lightburn.
Belts are tight as I can check.
Other ideas what could cause this?
Thanks for help.
Problem solved. A loose wheel. On the x Axxis.
