Help new to this laser cutting
Hi I have a 3018 pro with a 500nw engraver i am trying to cut through 0.8mm ply with out much luck have tried on 200 speed 100% power followed by 100 speed 100% power and although it is well marked it has not gone through Help
How many passes are you doing? You can just send the laser around 3-5 times, or whatever it needs to cut.
Check that the height and focus are correct, as this will make a big difference when cutting.
0.5w will give you a hard time cutting really.
Are you sure on the rating of the module?
Just not enough power density to cut through if it is in fact 0.5W
