Hello everyone!
I have a Due Flow ( Machines | Due Laser (duelaser-com.translate.goog) a Brazilian made C02 Laser.
I can configure the Due Flow in Lightburn but I can’t make it work properly. It used the GRBL driver on USB. Movements are working and so, but I can’t find a way to home and set the right coordinates.
It has a working area of 600x380 and every time it starting to cut it goes to a side.
The seller user support didn’t know how to configure to use LB - it uses a modified version of Inkscape with a plugin, but this software is way too bad to use compared to LB.
What information should I get from the seller that could help setup it properly on LB?
