goede morgen
ik zie het niet meer zitten,
Als men laser naar zijn home plaats moet gaan ,gaat hij de ander richting uit. en blijft hij tegen de kant staan trillen, precies hij nog verder wil gaan,
als ik beweeg met de pijltjes in het verplaatsingspaneel en duw rechts gaat hij links
ik denk dat alles ontregelt is
Wachten op verbinding…
ok
[AUTHOR: RenShen]
[MODEL: Ortur Laser Master 2]
[OLF: 137]
[DATE:01:15:16 - Apr 20 2020]
[VER:1.1f.20170801:]
[OPT:VZD,35,254]
Target buffer size found
ok
Naar standaardinstelling
ALARM:8
Homing fail. Cycle failed to clear limit switch when pulling off. Try increasing pull-off setting or check wiring.
ok
Ortur Laser Master 2 Ready!
OLF 137.
Grbl 1.1f [’$’ for help]
[MSG:Check Limits]
[MSG:’$H’|’$X’ to unlock]
ok
[MSG:Caution: Unlocked]
ok
[AUTHOR: RenShen]
[OLF: 137]
[OPT:VZD,35,254]
ok
ALARM:8
ok
OLF 137.
[MSG:Check Limits]
ok
<Idle|MPos:2.000,1.998,0.000|FS:0,0|Pn:X|WCO:0.000,0.000,0.000>
ok
Stream wordt gestart
[MSG:Pgm End]
Stream voltooid in 0:00
<Idle|MPos:12.000,1.998,0.000|FS:0,0|Pn:X|WCO:0.000,0.000,0.000>
ok
[MSG:Pgm End]
<Idle|MPos:2.000,1.998,0.000|FS:0,0|WCO:0.000,0.000,0.000>
ok
<Idle|MPos:2.000,1.998,0.000|FS:0,0|Ov:100,100,100>
ok
[MSG:Pgm End]
ok
[MSG:Pgm End]
<Idle|MPos:10.000,0.000,0.000|FS:0,0|Pn:Y|WCO:0.000,0.000,0.000>
ok
[MSG:Pgm End]
ok
[MSG:Pgm End]
ok
<Idle|MPos:10.000,0.000,0.000|FS:0,0|Pn:Y|Ov:100,100,100>
ok
[MSG:Pgm End]
error:20
Unsupported or invalid g-code command found in block.
Op of nabij lijn 2:
ok
[MSG:Pgm End]
ALARM:2
G-code motion target exceeds machine travel. Machine position safely retained. Alarm may be unlocked. (Right-click the ‘Devices’ button to reset the connection)
Op of nabij lijn 2:
[MSG:Reset to continue]
ok
OLF 137.
[MSG:Check Limits]
ok
ok
[MSG:Pgm End]
<Idle|MPos:0.000,9.996,0.000|FS:0,0|WCO:0.000,0.000,0.000>
ok
<Idle|MPos:0.000,9.996,0.000|FS:0,0|Ov:100,100,100>
ok
[MSG:Pgm End]
ok
ok
[MSG:Pgm End]
ok
ok
[MSG:Pgm End]
ok
ok
ALARM:3
Reset while in motion. Grbl cannot guarantee position. Lost steps are likely. Re-homing is highly recommended.
OLF 137.
ok
ALARM:8
ok
OLF 137.
[MSG:Check Limits]
ok
ok
[AUTHOR: RenShen]
[OLF: 137]
[OPT:VZD,35,254]
ok
ALARM:8
ok
OLF 137.
[MSG:Check Limits]
ok
ok
ok
[MSG:Pgm End]
ok
[MSG:Pgm End]
Stream voltooid in 0:12
ALARM:3
[MSG:Pgm End]
ok
OLF 137.
[MSG:Check Limits]
ok
2=0.002
$13=0
$20=1
$21=1
$22=1
$23=7
$24=600.000
$25=3000.000
$26=100
$27=2.000
$30=1000
$31=0
$32=1
$33=250.000
$100=80.000
$101=117.647
$102=80.000
$110=9000.000
$111=9000.000
$112=9000.000
$120=2200.000
$121=1800.000
$122=2500.000
$130=400.000
$131=430.000
$132=1.000
okxxxxxxxxxx.lbset (3.5 KB)
