Good question, maybe @Dskall can advise you… the idea is to educate, not do your work… next time you can teach someone else… ![]()
I explained in previous post. What part isn’t working for you?
thankyou to both of you for the help.
I did try the boolean tool but could not get it to work
Boolean tool will only work on two shapes at a time.
That’s “two closed shapes at a time”. ![]()
Here is another updated file as a suggestion.
fox logolb.lbrn2 (106.7 KB)
Thankyou Allen looks good will give it a try
Ungroup as necessary, separate parts, group parts marks etc. make duplicates. Place paw on marks. Select paw and marks. Boolean assistant Subtract B-A. Place duplicate paw back in place. Repeat for others.
I would suggest offset (outward) rather than a straight duplicate. A little white space would do wonders for legibility.
Thankyou will try it
