I’ve been slowly getting my GRBL Diode Laser working and had to redo my endstops for homing and then reorient my axis. Before doing this work I could select all of the image modes in the cut settings editor (dither, greyscale, etc.).
Now that I have the axis set correctly and the camera configured I can no longer select the mode for the image. The image mode is locked on threshold and the min power is greyed out.
In GRBL I have laser mode enabled. The PWM for the diode is set 0 - 1000.
But I don’t know if I changed a setting in lightburn that has casued this.
The reason you can not choose a different image mode is that you have ‘Pass-Through’ set to the ON (green) position. Pass-Through tells LightBurn to not touch your image, so none of the image processing modes are valid when on. If you want LightBurn to process your image using one of the image modes, turn ‘Pass-Through’ to OFF (dark-red).
