Help with GCode to Make Macros
First and foremost, I’ve got no experience in writing G-code/macros for Lightburn, and would like some help getting into it, if anyone would be so kind. I’m not asking anyone to make the Macros, I would like to make them myself so I can learn, but any help would be greatly appreciated!!! I’m trying to set up a few macros for Lightburn for my Atomstack A48 Ultra, mostly just to get the different cutting and engraving focuses set up (3mm and 8mm respectively). There is one that’s set up automatically with Atomstack with Lightburn, but its only for the engraving, and it doesn’t always work, and I’d like it to just do the autofocus vice autofocus then go to near home without homing. Any recommendations?
Below is what I’m working with + the planned coding
-The laser has a plunger to register focusing, which is hooked up to a Z-axis controller.
-Current Macro from Atomstack ([ESP500]) does the following: Zeros the Z-axis (goes to maximum height, triggers a switch), moves laser head down until plunger pushes against material, moves laser head up 8mm, then moves laser to the home position (without homing it).
What Macros I would like to make -
-Cutting: Z-axis zeros, goes down until plunger is tripped, Z-axis goes up 3mm, macro is complete.
-Engraving: Z-axis zeros, goes down until plunger is tripped, z-axis goes up 8mm, macro is complete.
-Proper Autofocus + auto-homing: the same coding as above, but with the command to properly home, not just to move to the 0,0 coordinates (don’t want expensive sounds).
Simple Functions Check - Zero Z-axis, move 1mm down, auto-home, then move the full length of the laser bed to ensure it can move properly without snagging (mine is 360x280mm). I was thinking like a framing action, where it would go from corner to corner, like go to 0, 360; 360, 280; 280, 0, 360, 0; 360, 280; Home.
Again, I am not looking for anyone to write these Macros for me, I would like to do these myself so I can learn. Any support would be greatly appreciated, and thank you to any who would like to help!!!
