Help with monogram on booleen function
Took a look at the file.
The GONZALES part is made up of hundreds of individual segments and is certainly not closed. Try ungrouping the name and then do Edit->Select open shapes and it will show you all the non-closed shapes.
Go through each letter and close each letter. You can use Edit->Auto-join selected shapes for ones that are well formed.
You could retype the letters and leave as text if that’s easier.
