Hi, need a little help with Rotary Setup.
When I use the Tools Rotary Setup - it works perfectly.
When I close that, and draw a rectangle that is same Y as Circ, it goes about 2 inches past that when I frame it. X is fine.
Why would Rotary Setup be spot on, but the normal Framing of Y be longer that Circ setting suggested.
So my hardware is 700x500 Red Blk
Y axis Steps Per Rotation is jumper set for 5000 (does it matter below?)
I have the CloudRay rotary roller (not chuck)
Roller Diameter is 67.5mm
Gear Ratio is 1.5
Object Mug Circumf is 12.875" (104.1)
Circle Pulse / Steps per Rotation: 11566.14
When I put the above in Tools Rotary Setup and click TEST, it works perfectly.
11566.14 Steps per rotation - 11566.14
67.5mm Roller Diameter
104.1mm Object DIameter
327.040mm Circumference
So I draw a rectangle in LB that is 50 x 327.04, and hit Frame, and it spins right past the start point by 2 or 3 inches.
I set my Origin as the far left start point on mug using Set Origin on Ruida, and use Top Left in LB, user Origin or Current Position both do the same thing.
I was thinking the extra movement was from it moving to my origin prior to framing, but my origin and current position are the same point.
Thoughts ?
Thanks,
Joe
