Help with settings, please
I recently changed my computer and reinstalled Lightburn and now my laser works on much weaker settings. Previously, it cut 10mm soft wood with one pass at 60%. currently I need 6 or 7 passes for the same job. Does anyone have an idea where it is in the settings? I have a sculfun S9SF-A9…Thanks
If you have access to the old computer you could try to bring the settings from there to the new computer using the bundles feature. File Menu> Bundles> Export Bundle on the old computer, select everythingthat you want to transfer. Then Import on your new computer.
