Hi everyone, I’ve been using Lightburn’s preview function to work out how long each job will take but am confused about some of the results.
I have a Redsail / Mainboard firmware version: RDLC-V8.00.47 (upgraded by Thunder Laser in the UK) and use Lightburn v0.9.11 to run it.
If I were to engrave a small square at 10mm/s and then do another at 20mm/s it halves the time. Exactly what I would expect.
I tried a different job and set it to 150 mm/s (25mins) then I tried it again at 250 mm/s but it said 24mins, where I would have expected it to be quite a bit less.
I’ve looked through the settings but I’m not sure which one might cause this. Is there a setting which determines the speed it moves from one engraving section to another and would it really make that much of a difference?
