Help with Transfer Failed
I move my laser to a different but same spec computer. I cant get it to move, It says ready but comes up with a message "
Transfer Failed lightburn 1.4.03
there was a problem sending the date to the laser. Machine may be busy or paused.
I have uninstalled , reinstalled and tried restarted the computer, what could I be missing.?
Installed the correct USB driver?
Does the laser get a COM port assigned you can connect to? (I don’t know xTool devices, but I think they should work the same as most others)
Yes, I have installed the correct one and uninstalled and re installed it. Thank you for your rsponse
So it works now?
Otherwise, check the output in the console window. If you see messages like “boot” and cryptic numbers, that’s probably a boot problem and you need to flash the firmware again.
You must also copy the LightBurn configuration files:
