Hi,
I recently installed a z axis motor on my laser and before I did so, for thicker materials I would manually adjust the z height and then run another pass.
I see that I can now set my line to two or more passes and then use the “z step per pass” setting to adjust the z height.
But my math-impaired brain needs help with figuring out what this setting should be.
I understand that “in” refers to not inches but cutting “in” to the material.
I cannot enter a value here of more than .3937
My step length value for the z axis in controller settings is .399999 and I’ve calibrated it so that it’s moving at the correct distance.
What if I wanted the Z axis to move 3mm toward the laser head on the second pass? Can someone give me an example of what I should enter here?
Thanks
Cheryl
