Hey guys i have a problem connecting my k40 to lightburn device cant be found
i dont know what is my laser ruida or grlb and i cant connect it to lightburn
i used meerk40 to connect it for the trial of the lightburn now i bought it and i cant connect it
If you used meerk40t initially to connect then you likely have a generic K40 using a Lihuiyu controller and using meerk40t for the Ruida emulation.
If that’s the case then you’ll need to make sure you purchase the “LightBurn Pro” license which includes DSP (e.g. Ruida). If you have not, then you won’t be able to connect to meerk40t the same way you did during the trial.
Can you confirm you have the LightBurn Pro license?
Note that meerk40t does also have a feature for g-code emulation but I’m not aware of anyone who has used it successfully.
just bought the extra liscence but it seems something wrong happen error or something…
What happens exactly? Can you take a full screenshot of LightBurn when this occurs?
What are you doing, what do you expect to happen, and what’s happening instead?
