I have imported a picture to trace but it didnt work out even adjusting the image, so i lined around the image with squares and circles etc with connect path and edited them after cutting parts of squares, lines and circles which formed the image i wanted, worked out quite well. I moved the image away to the side to see the traced results, perfect but when i moved back the traced part over the original, the traced part ended up underneath the original, not on top, so i couldnt see the compared results to check. How do i reverse the process to see the traced part over the original image rather than hidden underneath.
I can’t remember if it’s a select-rightclick or up on the the menu bar (arrange, maybe?) But you want to to “send to back” or something very close to that.
i have highlighted selected the image i copied and clicked push to back, nothing happened. Also done the same with push backward in draw order but still the same, either way selecting the drawing i done or the image i copied nothing happens.
I assume i have to select the image i want moving.
I deleted the picture that i was tracing and imported it again, for some reason what every i trace like a square circle or line is hidden behind the imported image, how do i reverse. it seems the push to back or front is not working under arrange, not sure whats happening here.
Can you upload the image?
I will try.
Isn’t your image on a different layer than the trace result? Just change the order of the layers, where you put the image layer under the trace result layer.
I did have a look at this and it did change the image and the drawing which ever one was selected, made it
