The Beam Buddy high resolution laser head is a replacement head for you laser. It allows you to engrave at a much higher quality than the stock laser head that came with your laser.
Its design makes the laser beam more focused into a smaller focal spot than the standard laser head, which makes the engraving result more detailed. It is suitable for engraving high precision photos and also a good performance on 3D engraving. Besides, because of the very small laser dot with high energy density, testing has shown that it can actually cut substrates up to 3mm in thickness at approximately twice the speed as a standard 2" lens system.
For more information go to https://hub.beambuddy.xyz/shop/
