Home button wont work after lastest lightburn update
Everything was working fine yesterday and today I did the latest Lightburn update and now the home button won’t work immediately, i can press the home button 15 times or more before it gets the message. Im using lightburn with an xtool D1 pro. Any suggestions?
I am having the same issue.
Do you mean you click it 15 times or so, and then it finally does home?
Is there anything reported in the Console that you could Copy+Paste into a reply here for us to review? When you send a home command, it should be visible in the console for GRBL devices like your D1
Try loading a backup file from yesterday..
If you use an xtool with LB and have a working combination, never do any update :slight_smile: Neither the firmware nor LB.
Nor Windows! :grin:
